GT-E or XR7-G Hood scoop differences?
v194
#1
Post by v194 » 18 Jul 2018, 20:03
If this is the wrong section for posting please let me know but what is the difference between the two scoops?
And
What is the measurement between the scoop openings (inlets) on the front of the scoop?
Thanks
MercuryDon
Contact:
Re: GT-E or XR7-G Hood scoop differences?
#2
Post by MercuryDon » 19 Jul 2018, 01:23
GTE does not have the vertical bars in the openings
68 427 GTE-XR7 Dk Blue/Dk Blue(1 of 3 Color/trim) C6 3.50TL
68 390 4V XR7G Dk Blue/Dk Blue w/Sunroof C6 3.25TL
69 428SCJ 4spd XR7 Conv't.White/Aqua 12K miles(1 of 1 with 4.30DL)
69 428CJ 4Spd Cyclone CJ Maroon/Blk 29K miles 3.50TL
68 390 4V Cyclone GT. Madras/White C6 3.00 (Introductory Show unit)
69 390 4Spd XR7 Sunroof Med.Lime/Dark Ivy 3.00
68 390 4V Cyclone GT White/Red C6 3.25
04 Cobra Conv't.4.6 DOHC Supercharged Blk/Grey 3.50TL
70 390 Javelin SST Big Bad Grn/Blk 700R4 4.10 Dana 44
98 Dakota R/T 5.9 Std Cab Blue/Grey(1 of 32) 3.91SG
71 Thunderbird 429 w/suicide doors Copper/Drk.Brn 2.75
06 Dodge SRT10. 11k miles 488 cube Viper V10. 505hp. 6 spd. 4.10SG
v194
#3
Post by v194 » 19 Jul 2018, 05:01
Great Thanks!
Anyone on the measurement as identified on the photo above?
19cougar68
#4
Post by 19cougar68 » 19 Jul 2018, 06:54
Sorry to hijack this post but I am having difficulty deciding which style, GTE or XR-7G on my project. I would like to make the scoop functional. On the XR-7G I can see where simply removing the material between the grates is doable. What about the GTE scoop? Being fiberglass if I remove the recessed areas to make the scoop functional would the scoop become flimsy over the cutouts whereas the XR-7G style has the vertical grate supports?
Has anyone made either of these scoops functional? Would appreciate any feedback. Thank you, Jim R.
1967 S Code
#5
Post by 1967 S Code » 19 Jul 2018, 09:51
The both scoops can be made functional and it has been done in the past. One important thing to keep in mind is the fact that you need a ram-air air cleaner with a seal for the hood. If you don’t the scoop will only let hot air out of the engine compartment rather than forcing cooler air into the breather element.
Our Cougars
1967 Standard
Dan Gurney Special
1968 XR7-G
1968 XR7-G Hertz
1967 S Code
#6
Post by 1967 S Code » 19 Jul 2018, 09:52
I can get the measurements for both scoops later this evening.
Our Cougars
1967 Standard
Dan Gurney Special
1968 XR7-G
1968 XR7-G Hertz
19cougar68
#7
Post by 19cougar68 » 19 Jul 2018, 10:52
Steven, thanks for the reply. Since the real Ram Air stuff is so expensive I was just going to foam seal my existing air cleaner housing with a smaller 14" chrome cover. Thanks for the input and sorry to the original poster for the hijack. Jim R
1967 S Code
#8
Post by 1967 S Code » 19 Jul 2018, 11:05
The measurement in question is 8 3/4” for both.
Our Cougars
1967 Standard
Dan Gurney Special
1968 XR7-G
1968 XR7-G Hertz
xr7g428
Site Admin
Site Admin
Contact:
#9
Post by xr7g428 » 19 Jul 2018, 13:44
19cougar68 wrote:
19 Jul 2018, 06:54
I have a Cougar with a cut out scoop. My conclusion is that the cut out area is too small and located too close to the hood to actually do anything. If you want a scoop that can work you need to look into the scoop used on the R code cars.
Legendary Cougar Magazine
Currently in the Cat House
v194
#10
Post by v194 » 19 Jul 2018, 16:47
1967 S Code wrote:
19 Jul 2018, 11:05
Thanks Steven. Just so I am clear the middle section is 8.75" on both of the styled scoops?
