I have just finished restoring my 1968 Cougar, 302 cid/4bbl., with factory restored A/C. The blend doors for the the A/C move when I accelerate or decelerate. For example: With A/C on MAX, air blows through the dash vents normally. But if I accelerate like passing on the highway, the blend door(s) cycle and air comes through the heater vents. New vacuum canister. Good vacuum check-valve. New vacuum lines.
Any one have an idea on what's happening here?
ttp17
Air Conditioning blend doors
Re: Air Conditioning blend doors
Bad vacuum check valve or vacuum leak. Minus vacuum, the motors return to the default position (heater or defrost).
Legendary Cougar Magazine
Currently in the Cat House
Yes this was the problem. I sent a thank you , but it did not get thru. So, thanks again.
