Mystery NOS bolt found in New Years Clean-up
gah
#1
Post by gah »
I hope that someone in the CCC can help to identify this bolt, which I purchased long ago, and failed to tag for its application. I've searched the internet and also compared it to other reproduced ( AMK ) chassis / suspension bolts which has yielded no matches or leads. I could search through all the MPC diagrams for my 1969 Cougar, but that would take a very LONG time to chance upon where the bolt is used !
I know for sure that it is not the rear leaf spring ( front eye bushing ) bolt - as I have one of those ( it is significantly longer ) and it is not this part number.
It is Ford part / hardware number : 38822-S100 ( BB-199-EC ) And I've attached some images.
Thanks for any help as to what this bolt is used for.
mo2872
Contact:
Re: Mystery NOS bolt found in New Years Clean-up
#2
Post by mo2872 »
Looks about right for an engine mount bolt to me.
T3
Yup, that guy, the hooligan.
How do you know someone is a pilot? Easy! They'll tell you!
Royce
#3
Post by Royce »
It shows applicability as follows and Replaced By
-386273-S437M :
Ford
Aerostar
1991-1997
6 Cyl 3.0L, 6 Cyl 4.0L
4AT 4R44E, 4AT 4R55E, 4AT A4LD, 5AT 5R55E, 5MT
Ford
Bronco
1992-1996
6 Cyl 4.9L, 8 Cyl 5.0L, 8 Cyl 5.8L
3AT C6, 4AT A4LD, 4AT AOD, 4AT E4OD, 4MT, 5MT
Ford
Bronco II
1990
6 Cyl 2.9L
4AT A4LD, 4AT AOD, 5MT
Ford
Escort
1987-1990
4 Cyl 1.9L, 4 Cyl 2.0L Diesel
3AT ATX, 4MT, 5MT
Ford
Explorer
1991-1994
6 Cyl 4.0L
4AT A4LD, 5MT
Ford
Explorer Sport
2001-2003
6 Cyl 4.0L SOHC EFI
5-Speed Automatic Transmission - 5R44E/5R55E, 5-Speed Manual Transmission - R1HD, Four-Wheel Drive (Part Time), Rear-Wheel Drive
Ford
Explorer Sport Trac
2001-2005
6 Cyl 4.0L SOHC EFI
5-Speed Automatic Transmission - 5R44E/5R55E, 5-Speed Manual Transmission - R1HD, Four-Wheel Drive, Two-Wheel Drive
Ford
F Super Duty
1992-1997
10 Cyl 6.8L, 8 Cyl 7.3L Diesel Turbo
4AT 4R100, 5AT, 5MT, 6MT
Ford
F-150
1990-1996
3AT C6, 4AT 4R70W, 4AT 4R75W, 4AT AOD, 4AT E4OD, 4MT, 5MT
Ford
F-250
1990-1997
6 Cyl 4.9L, 8 Cyl 4.6L, 8 Cyl 5.0L, 8 Cyl 5.4L, 8 Cyl 5.8L, 8 Cyl 7.3L Diesel, 8 Cyl 7.3L Diesel Turbo, 8 Cyl 7.5L
3AT C6, 4AT 4R70W, 4AT AOD, 4AT E4OD, 4MT, 5MT
Ford
F-350
1990-1997
6 Cyl 4.9L, 8 Cyl 5.8L, 8 Cyl 7.3L Diesel, 8 Cyl 7.3L Diesel Turbo, 8 Cyl 7.5L
3AT C6, 4AT AOD, 4AT E4OD, 4MT, 5MT
Ford
Ranger
1999, 1990-1997
4 Cyl 2.3L, 4 Cyl 2.5L, 6 Cyl 2.9L, 6 Cyl 3.0L, 6 Cyl 4.0L
Ford
Tempo
1984-1994
4 Cyl 2.0L Diesel, 4 Cyl 2.3L, 6 Cyl 3.0L
3AT ATX, 4MT, 5MT
Ford
Windstar
1995-2003
6 Cyl 3.0L, 6 Cyl 3.8L
4AT 4F50N, 4AT AX4S, 4AT AXOD-E
Lincoln
Mark VII
1990-1992
8 Cyl 5.0L
4AT AOD
Lincoln
Town Car
1984-1989
8 Cyl 5.0L
4AT AOD
Lincoln
Versailles
1980
8 Cyl 5.0L
3AT C4
Mercury
Grand Marquis
1990-1991
8 Cyl 5.0L
4AT AOD
Mercury
Lynx
1987
3AT ATX, 4MT, 5MT
Mercury
Topaz
1984-1994
3AT ATX, 4MT, 5MT
Mercury
Tracer
1987
4 Cyl 1.6L
3AT ATX, 4AT 4EAT, 4AT F4E-III, 4AT IF4E, 4MT, 5MT
gah wrote:
02 Jan 2020, 15:51
XR7-G Registrar
Midlife
Contact:
#4
Post by Midlife »
JWC66K on the ConcoursMustang forum has documented all hardware used for each year and its application. For 69/70, here's the link:
http://www.concoursmustang.com/forum/in ... ic=10790.0
You may have to be a member to access the library, however. Hope you find it there; I only looked for 69/70's. All years can be found at:
http://www.concoursmustang.com/forum/in ... board=22.0
