68 sun roof panel
There were only 619 XR7-Gs built. They were built along side the Shelby Mustang, and were available with every engine and transmission offered in 1968, (except the 427). This was the first Cougar to be a part of the Hertz Rent a Racer program. If you have any information about these rare cats, this is the place to share. The XR7-G registry is maintained by Royce Peterson.
68 hertz
68 sun roof panel
#1
Post by 68 hertz »
I would like to remove the panel, book says open it 3 “, but with everything disconnected I’d rather not try and power it up. I don’t want to damage anything can I just remove the flex drive and turn it by hand, having not worked one just getting a little insight
Randy ,Syracuse NY
Royce
Re: 68 sun roof panel
#2
Post by Royce »
That would work.
XR7-G Registrar
tattarat
#3
Post by tattarat »
There is also an override. There are a couple different kinds, but mine could be done with an ordinary screwdriver. Here is where the override is and a picture of one type of tool.
You do not have the required permissions to view the files attached to this post.
tattarat
#4
Post by tattarat »
Nuther picture of the override...
68 hertz
#5
Post by 68 hertz »
I have that wrench but Because it threads in and will only move the mechanism one way from an open position to the closed position in the event of a powering failure, I’ll check it out.
Randy ,Syracuse NY
tattarat
#6
Post by tattarat »
if the thread area is long enough on the tool, you may be able to put a nut on it ( all the way to the end of the threads ) then thread the tool into the override, and tighten the nut to keep it stationary for turning in either direction ... Hope that makes sense. It's how I install studs... I put two nuts on the stud tightened together and I can turn the stud either direction.
Royce
#7
Post by Royce »
Just remove the motor and drive shaft and then you can turn the gearbox in either direction.
XR7-G Registrar
68 hertz
#8
Post by 68 hertz »
Yup that’s what I’m going to do
Randy ,Syracuse NY
68 hertz
#9
Post by 68 hertz »
I haven’t had a chance to do it yet but I have to get it done I got a buyer for it. Thanks for all the input.
Randy ,Syracuse NY
